Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Rear Air shock adjustment
Old 09-20-2014, 02:50 AM
Lucky1967's Avatar
Lucky1967
Lucky1967 is offline
Default Rear Air shock adjustment
I have a 2012 SG and found that there are 12" shocks on it, which I'm assuming it was lowered from stock. First question is: what are the stock shocks for this bike,13" ? And 2nd question: Is there a chart to see how much air to put in the shocks for the optimal ride? I'm 6'3 and 250lbs if that helps.
Thanks
Old 09-20-2014, 06:00 PM
Double S's Avatar
Double S
Double S is offline
Stage IV
The Ultra came with 13'' and SG came with the 12'' from factory. Your owners manual will give you the pressures but you going to need the Harley hand pump to fill them.
Old 09-20-2014, 09:11 PM
Lucky1967's Avatar
Lucky1967
I bought it from an auction place and a manual didn't come with it. The ad said that it had a lowered rear suspension which is why I figured that the shocks were changed. I might try the 13" shocks and see if that helps with my position on the bike, feels a little cramped right now, also might try a tall boy seat.
Old 09-21-2014, 04:25 PM
97classic's Avatar
97classic
97classic is offline
Stage IV
Default air shocks
Do not exceed 35 psi on rear and 25 psi on front...that is what the owners manual states. I usually run them on 10 psi when I am alone..Same weight as you.
Old 09-21-2014, 11:36 PM
Lucky1967's Avatar
Lucky1967
Thx that's all I was wondering. I'll bump it up to 10 as soon as I get a Harley air pump and see how it feels.
Old 09-21-2014, 11:46 PM
Deuuuce's Avatar
Deuuuce
Deuuuce is offline
I went with 13s myself since 12s only offer 2" of travel. You may also want to search for the oil change thread for the shocks (yes, they have oil in them) or just upgrade altogether.
Old 10-17-2014, 10:47 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
You can get the owners manual as a book from any Harley dealer, or download it from the H-D website, go to the Owners tab.
Old 01-26-2015, 01:28 AM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
I believe the newer bikes have a 50psi max for the shocks. The forks no longer have air...
bigdawg06
06-29-2016 12:16 AM
13bob
09-14-2014 07:29 AM
shrekofd
04-15-2013 02:53 PM
sweetbillebob
10-07-2007 07:24 PM
Big Ted
08-13-2005 12:05 AM
Quick Reply: Rear Air shock adjustment
