Older CVO style switches on a 2014 for airride?
Has anyone attempted to use the older style CVO air ride lock/unlock switches on their 2014+ bagger? I ordered the switches already but realized that the dash panel buttons are smaller on the newer models. The CVO switches are too big, now Im wondering how Im gonna get it to work...
I have the unlock lock buttons on the right side of the dash. You need a dash aux sw assy. its the same as the left side that comes with aux passing lights. You need to order the lock and unlock buttons to go in the switch. They also have AUX switches. some are on/off and some are momentary but you can modify the on offs to be momentary. Both aux switch panels plug into the factory harness which ends up at the 6 pin Aux plug under the side cover. I wanted to keep my left side available for the AUX DRIVING LIGHTS so i used the right. I also used the CVO lock and unlock momentary buttons as up and down for the rear air and the third is an on/off AUX button for LEDs underneath. The trick is that the 3 poles on the Aux plug that these buttons activate, need to be removed from the plug so that you can use them as you wish. Another option is to get the HD AUX harness and buy the pin connectors to fit into it because it has 3 blank spots, the other wires on the AUX harness are controlled by the left side switch assy which has one button pre wired for lights and the other two control the Aux harness.....I hope you can follow my mad rambling
I came up the part number 71400033 for the CVO Lock and Unlock.
Did you just splice into plug under left side cover?
Anything else that I will need?
Thanks!!
Chrissyflstf08
Screamin Eagle CVO Models
11-25-2013 09:30 AM
