The remote is the one that is going to suck . Has a separate solenoid and a few wires . Im going into this blind no instructions . The mounting not so much , the wire's is the issue .
my instructions dont show it with the remote...i would just ditch it u would never use it, that would suck to dump or raise the bike from a remote and watch it tip over 10 feet infront of you.....the wireing as far as the shocks are orange wire on compressor to batt+ terminal black wire goes to one side of the switch the other side of switch goes to a chasis ground....
Can you download instructions from the high low web site if there is one.If not Im sure a company that sells that system can get you them or has them on a site where you can get access to them.I would wait before going in blind.Good Luck.
