SAS air ride Vs. Shotgun Shock install and review thread...
I have ridden more with it. It is different than the Shotgun. It responds differently over big bumps and firms up much quicker. If I had a bike with abs I would not hesitate to put the SAS on it, but a bike without abs i would do shotgun.
Drew
Drew
Big Lou's Garage (01-06-2023)
Changing trans fluid on a softail with shotgunshock takes an extra 5 minutes
Just remove the two hex bolts securing the shotgunshock to front frame gusset and shock pivots into a vertical position, allowing access to trans drain plug, no need to remove shock from swingarm and air line and electrical plug stay intact.JD
If you want a quicker response, click on JD1's name and send him a private message.
ShotGun Shocks Update
Hello everyone, I installed the Shotgun Air Shocks on my 05 Fatboy and what a difference, I can control the ride height and the amount of cushion by flipping one or both toggle switch's. I had no problems with installation or air leaking out. It works Great & I am very pleased with the product. I am not affiliated in no way to Shotgun Shocks, I just wanted folks to know that it makes riding so much easier on older bones-Tim in MI
