Advice using Air suspension pump.
I have a 2000 Electra Classic. I bought a Harley hand pump yesterday because i'm riding with NO air and I have a wobble at high speeds.
I'm able to screw the pump to the stem and pump it to my desired 23psi with no issue on each side.
My problem is I seem to be losing ALL of my air as I unscrew the pump from the stem. I called the Harley dealership and they said to unscrew it faster I tried that (knowing there was no way that it could be done that quicly) and of course the air still came out to Zero. I have no way to check existing pressure either. When I hold the pump to the stem to check the pressure it reads zero and oil comes out.
Am I using the pump incorrectly? There is a button on the model pump from hatley that I have if that helps.
Excuse my lack of knowledge with this, i'm learning.
I'm about to take a ride from ATL to Memphis in the morning and I need to get this take care of today !!
For what you pay for these things, you would expect them to be perfect the first and every time you use them.
.......martin
