Air leak rear shocks
Hi, I'm a new member just bought my first Harley is an 09 Electra glide ultra classic, I was reading the owners manual and I notice that the bike has air shocks I went to check the air and it was at zero, so I put air in it with a hand pump to 40 psi but 1/2 later it only had 20 psi! I'm assuming I haver a air leak but how do i check?Thank you
I have used an ordinary bicycle pump for many years (well, over 20!) plus a low pressure pencil guage. As Mike points out if you use a similar setup you will lose a lot of air just connecting and disconnecting the pump. However there are dedicated pumps available, with built-in guage, which will not lose that precious air. Your local dealer can supply, or you may find them on Ebay.
Tire rub with air shocks?
I have a 2011 Street Glide that I just put 21" front wheel and 17" back wheel w/ 200 tire. My next step is the Legend Air shocks. The 2011 Street Glide stock shock is 12".
I am a short guy with a 29" inseam and current configuration I am flat footed. My options are 12" or 13" Legend air shocks whereas the 13" will give me a better ride but will be higher off the ground. Questions are:
1) do I go with the 12" or 13" air shock
2) does anyone know of rubbing issues with this size tire if you competly lose air pressure.
albngore
03-20-2017 01:30 PM
