Is 8 gauge wire too much
Old 11-03-2014, 11:28 AM
redneckharley's Avatar
redneckharley
redneckharley is offline
Default Is 8 gauge wire too much
I have finally got all the parts to start my RF PBR300x4 amp and speaker install. I know Ultra and Gannicus recommend to use 10 gauge wire to power and ground the amp. A friend had some 8 gauge wire left from his install and I was wondering if it would hurt to use that 8 gauge wire to power and ground my amp? Thanks for your assistance
Old 11-03-2014, 12:07 PM
SmokeyJoe101's Avatar
SmokeyJoe101
SmokeyJoe101 is offline
Bigger is better, especially if you want to upgrade or add on later.
Old 11-03-2014, 12:52 PM
redneckharley
Thanks Smokey, spent too much money to see it SMOKE!!! No pun intended. Where are you in Germany?
Old 11-03-2014, 01:02 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
Smokey's right . . 8 gauge is fine.
Old 11-03-2014, 01:05 PM
Melman's Avatar
Melman
Melman is offline
Bigger is always better for a ground. The only limiting factor could be if you need to go thru an existing hole or make a sharp bend.
Old 11-03-2014, 02:17 PM
AAWAV's Avatar
AAWAV
AAWAV is offline
Thicker will never hurt... gannicus and the others are correct...
Old 11-03-2014, 05:48 PM
just plain john's Avatar
just plain john
just plain john is offline
I just did a PBR install using 8 gauge wire. The connection at the amp will accept 10 gauge, but 8 gauge is almost too big to fit.
Old 11-03-2014, 06:01 PM
redneckharley
Thanks all. My next question is what do ya'll think of my mounting idea for the PBR300x4 amp. Im thinking about mounting it beside the CB box on top of factory head unit. It hangs over about and inch, do you think it will rub the front facia. If I have to I can cut one end of the amps mounting holes off to make it sit even on the end. What Im trying to do is get the setting ends on the outside so to make it easier to work with and give it better ventilation. Im open for all suggestions I only want to do it once and right.
Old 11-03-2014, 06:29 PM
just plain john
UltraNutZ can tell you better than I, but I think he moves the CB module to the bottom and puts the amp on top of the head unit. Another option is to trim the bucket that holds the speedometer to allow the amp to sit back further, a mod he did to my bike when I had the SoundStream 520 in there
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,953 Likes on 1,685 Posts
Why not just use rebar?
Seriously, 10 gauge wire is rated for 55 amps, 12 gauge for 41 amps. Unless you plan on welding with it, you do not need 8 gauge wire.
Quick Reply: Is 8 gauge wire too much
