Looking to add an amp
I had the same question about the R1 setup when I started looking to upgrade. The answer was essentially, no. It sticks with 5.25 speakers and while matched to the amp that amp is not very powerful. If you're going to do the upgrade make it matter. For a few dollars more going with the setup AAWAV suggested you'll get 6.5" speakers and an amp that is a beast for a 2 channel.
Still looking to see if the Hawg Wired bracket will work. Don't want to run the amp on to of the radio and burn it up or something and make things worse. Not to mention the fact I'll have to move the interface.
Amp -
Speakers -
Adapter rings - http://www.ebay.com/itm/ARC-6-5-SPEA...6bd56c&vxp=mtr
That should save you some time.
Amazon.com : Rockford Fosgate PBR300X2 Punch 300-Watt 2-Channel Boosted Rail Amplifier : Vehicle Stereo Amplifiers : Electronics
Speakers -
Amazon.com : Infinity Kappa 6.5" 2-way Loudspeaker-Pair (Black) : Component Vehicle Speaker Systems : Car Electronics
Thanks. That amp is huge. Not sure if I want to have to remove the cross brackets. my have to find a bracket for the top of the radio and move the interface to the side via Hawg Wired bracket.
I would like to avoid Amazon if at all possible. They have a distribution center in TN which make me end up paying sales tax...9.5%.
Sorry....search came up wrong! That's the X4. Here is the amp you want Amazon.com : Rockford Fosgate PBR300X2 Punch 300-Watt 2-Channel Boosted Rail Amplifier : Vehicle Stereo Amplifiers : Electronics
http://www.sonicelectronix.com/item_...FURo7AodXUIA3Q
Believe it or not, it's relatively small and fit easily on top of the radio if there's no cb. The PA or SS amps just barely fit.
