Install Speakers/Need Amp Recommendation
  #51
Old 02-15-2015, 04:32 PM
ALUCARD19's Avatar
ALUCARD19
ALUCARD19 is offline
If you want to keep your FM and are only running 2 speakers then you can also go with the RF T400x2ad amp great specs but a little costly.
  #52
Old 02-15-2015, 04:57 PM
sgr60's Avatar
sgr60
sgr60 is offline
I've been on the fence about what amp/speakers to get myself, and I've been putting it off. BUT, after reading this, I decided to pull the trigger and go with the PBR300X2 and a pair of Infinity 62.11i speakers. Looking forward to it.
I did also order a set of 5.25" to 6.5" adapters for the speakers. I know I'll need some wire and fuse as well, is there anything else that I'm missing other than just regular wiring stuff?
February in NE - if I can't ride it, I'll just have to work on it instead!
  #53
Old 02-15-2015, 06:40 PM
speedracer's Avatar
speedracer
speedracer is offline
Originally Posted by sgr60
I've been on the fence about what amp/speakers to get myself, and I've been putting it off. BUT, after reading this, I decided to pull the trigger and go with the PBR300X2 and a pair of Infinity 62.11i speakers. Looking forward to it. I did also order a set of 5.25" to 6.5" adapters for the speakers. I know I'll need some wire and fuse as well, is there anything else that I'm missing other than just regular wiring stuff? February in NE - if I can't ride it, I'll just have to work on it instead!
Are you also from Ne ---- Omaha here----
  #54
Old 02-15-2015, 06:52 PM
sgr60's Avatar
sgr60
sgr60 is offline
Actually meant New England - I'm in CT
drew1879@gmail.com
Audio Systems
05-12-2016 09:37 AM
2007z71
Audio Systems
03-29-2015 10:53 AM
rome304
06-02-2013 08:42 PM
HighLiner
09-18-2012 08:05 AM
Mixter
09-05-2011 10:32 AM
Quick Reply: Install Speakers/Need Amp Recommendation
