HogTunes Fail
So my recommendation --- Do whatever Gannicus says!! That was easy!
Honestly though if you can swing a full BT set-up do it. Call Bill let him know you are a forum member, tell him what you are looking for and he'll take care of you down the last connector you'll need. If you want to stay close to your initial investment get the Kickers for the rear. What I'm not sure of (and Gannicus will know) is will the 6.5's drop right in, and do the Kicker or Titan II grills fit.
Best part is when you turn it on, you'll grin, smile, then laugh at the stuff you just returned.
If you can do that in 15 minutes. The BT install will take you 30 min.
Nice...! I will call Bill... Ya, if I can find out about the speaker size difference and if the new ones fit, if I have to buy new grills.. etc.. I am sure Bill will know that as well
Rears...mmmm, yeah Gannicus knows. (I'm sure Bill does too).
Good luck man.
Hey guys, I only received a response from a Robin from biketronics so far. I PM'ed biketronics by have not heard back from Bill..
Robin's response was this..
We recommend this kit: http://www.biketronics.com/ultimate-...mbo-with-pods/
**The 4 channel amp will permit front/rear fade and can be expanded to 8 speakers on the bike, if you want add lowers/lids.**
This would be a more cost effective solution: http://www.biketronics.com/bt2180-am...r-speaker-kit/
**Our BT2180 will run four speakers but its maxed out, so no more expansion down the road.**
All of our amp and speaker kits come with everything you need to complete your installation and are backed by our lifetime warranty
I think maybe I just need to call there to talk to Bill? I haven't got anything about a discount for forum members. I am expecting a call fro Hogtunes with my refund tomorrow. If that is the case, I want to get this stuff on order...
I am sure I can call and talk to Bill tomorrow also...
HogTunes system back to Canada now. Been talking to Robin at biketronics. I think I've made up my mind to go with this system... I know I could get away with the 2180 amp, but after some thought, if I ever do decide to add anything else, I'm good. Also I don't lose fade.
Should have my refund from HogTunes this week, then I will order the one from biketronics... Sure hope it's a complete 180 experience...
Gannicus... Do you recommend a particular spot for getting the kicker speakers. If I order the kicker speakers, I would assume I will still need to tell biketronics that I need any wiring harnesses for the rear speakers also? These are not purchased from them right. If I only buy the amp and front speakers from them, I would assume they will only send me the things needed for the batwing?
http://www.crutchfield.com/p_20641KS...1255385&awdv=c
No need for a wiring harness for the rears. The speakers simply connect to the amp. Bill has all kinds of harnesses for different applications though. You might check with him when you call him. He's always got something to make your install easier.
