orange wire has no power
I misunderstood what he was asking. I thought he was simply trying to wire his HU. NHRider if you answered as many questions as I do on a daily basis your advice might get a little faulty as well. For the record I don't give out faulty advice. But then again nobody is perfect. . .
Quoted:
most people tell me that I can use the orange wire with a white stripe under the seat running back towards the tail lights
Didn't mean to cause any problems.
every one of you guys has been a big help I think I've been going about this the wrong way coming off my head unit there is a red wire a yellow wire black wire which is a coarse ground and then the blue wire which of course is power antenna or Amp. does this sound like the yellow wire needs to go to the battery because it controls the clock in the memory it have to have constant power the red wire needs to go to a switchable hot lead which will control the on and off if this is the case what I am doing is this exact opposite I had red going to the battery yellow wire going to a switchable power source so when I would turn the key off the switchable power source would shut off and I would lose my memory and my clock does this sound about right to you Guys am I on the right track now
Red to Switched Power.
You had them reversed.
