What the Heck is my Problem?
I'm at my wits end with my new sound system. I replaced my SoundStream PN4.520 this spring with a BT4180. Main reason was FM reception, but the sound quit working on my ride from the dealer to home this spring so that even gave me more reason to replace the SS. Well I am now on my 2nd BT4180 and still having problems with sound. Both BT4180's worked fine in the garage, but later the sound completely stopped. I spent time on the phone with Robin at Biketronics with the 1st amp checking everything out with a multimeter. Finally, we decided it needed to be sent in. BT sent me a new one and all was good. I even replaced my 4 1/2 year old battery thinking this could be the problem. All worked fine until this evening. Started bike up tonight for a short ride and believe it or not - no sound. Man I can not figure this out. I can even hear the amp fan running but still nothing. Running Polk MM651's (2 front, 2 rear) and stock radio. Now, I really don't believe that the amps are the problem.
Any thoughts would be appreciated. Thx.
I thought of that but when I bypass the amp with my old stock speakers all works fine. I am also getting good sound from the headphones that came with the bike. Seems to me the HK unit and BT4180 don't want to play good together. I have a call into BT to see what else I can do. I'm almost to the point of buying an aftermarket radio.
Hmmm The old tricky fuse holder huh! Good follow up margin. Your experience will help the next guy troubleshoot. Including myself. I would not have guessed a fuse with three different amps. usually when a fuse blows it's done until it's replaced. In other words when biketronics sent you the replacement amp you should of had the same issue.
