2 Channel amp running 4 spk's ?
i did a little searching as i am not that familiar with the hogtunes lineup but what i found says their speakers are 2ohm and the amp does 70x2@2ohm, so currently each speaker is getting the full power the amp can produce. you could add another set of 2ohm speakers but you would have to run them in series. in that scenario the amp would see a 4ohm load and it's power would be reduced to around 40 watts per channel, so 20watts per speaker (these are approximations, but in the end it would most likely not be as loud as your current setup).
based on that info it would not be worth it. you would need a bigger (more power) amp to upgrade your system.
