call me an idiot …need help asap
Old 07-02-2015, 06:44 AM
mslater741's Avatar
mslater741
mslater741 is offline
Default call me an idiot …need help asap
got my sony mex -m70bt and metra 99-9600 kit yesterday ….cant get the sony to go into the metro bracket ….whats up with that ? do i need to take the face off the radio somehow ….dont understand the jap hieroglyphics
Old 07-02-2015, 06:46 AM
96roadking's Avatar
96roadking
96roadking is offline
idiot, Egyptians used hieroglyphics! J/K good luck
Old 07-02-2015, 07:16 AM
Smokey Stover's Avatar
Smokey Stover
Smokey Stover is offline
Remove the rectangular mount bracket from the HU. That's for an automobile install.
Don't try modification of the faceplate!
Old 07-02-2015, 07:23 AM
Smokey Stover
This thing.
Old 07-02-2015, 07:28 AM
mslater741's Avatar
mslater741
i see that but not sure how to remove it , but more than that the metra bracket is at least an 1/8 " narrower than the sony
Old 07-02-2015, 07:35 AM
mslater741's Avatar
mslater741
Originally Posted by Smokey Stover
This thing.
ok i just figured how to remove that sleeve thanks but its still a good 1//8 inch to small
Old 07-02-2015, 07:38 AM
Smokey Stover
Lift/release the tabs on the side. It's supposed to fit snug/tight. It will fit if you got the right kit for a Sony.
Old 07-02-2015, 07:47 AM
mslater741's Avatar
mslater741
do you need to remove the black plastic ring of the face plate too ? the radio is 7" wide the opening in the metra bracket is 6 ⅞" wide, it just won't go in from the back of the radio
Old 07-02-2015, 07:52 AM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
Sure do.
2010 Limited with some stuff
Old 07-02-2015, 08:00 AM
Smokey Stover
No, the Hu should slide in through from the rear and fit against/behind the trim. Double check the install instructions that came with the Metra. Maybe one of the real experts wil chime in. I have a different Sony HU and Biketronics Retro kit,But they're basically the same.
Quick Reply: call me an idiot …need help asap
