Arc Audio Moto 602's & Cerwin Vega B2
Hi all,
I bought a 15 RGS back in April and looking to upgrade the fairing speakers with an amp. Been looking at the Arc Moto 602's with a Cerwin Vega B2 amp.
Anyone have input for this combo? I've read all the outstanding reviews for the speakers, not sure if the CV is a good option to power the speakers. Trying to get best possible sound with just upper fairing speakers, amp, and required wiring harnesses for a max budget of $700.
If there are opinions on other speaker/ amp combos in the budget range I'm open those as well.
I'll let you know as soon as i hook everything up after the pac sni-35 shows up, hopefully today. I was able to get the 602's, B2, and all associated stuff (polyfill, a little dynamat, sni-35, and knuconcepts speaker wire) for around $425. I'm installing in a street glide, but should give you an idea.
I should add that i will have wait until Monday or Tuesday to get the radio flash done.
Ok. I got everything installed over the weekend and was able to get the flash done today. Without pushing it too much i will say this: so clear, louder, and i am happy. This is my first bike with a stereo and first audio upgrade on a bike.
The install went fairly smooth. Definitely need a knuckle to get at one damn f$@/#ing bolt to get the batwing pod out lol. I took the advice of haze by going with a 3" hole in the pod. I also added polyfil, loosely, and also put some dynamat on the inner fairing.
I don't have much to compare this set up to, but for around $425 i am very happy. Looking forward to the 602's to break in and get a little more low end.
Ride safe man, enjoy the tunes.
I should add. I took the stock grills out and temporarily put the pods and speakers in their place in order to aim the tweeter at my head. The mid highs to highs are so crisp, even at 60 mph.
And I'm using the latest update, 1.19 and followed biketronics recommended flash, http://www.biketronics.com/pages/Support.html, but the dealer was unable to check yes for the amp under the options tab.
The 602's went in with no modification. Pretty much the easiest part of the whole job.
