Rushmore Tour Pak Speakers?
The LL only comes into play when an after market Amp is installed. LL's are not needed for speaker upgrades. Because of there size, BT shipped mine out USPS Priority Mail and I had them in three days.
I am not familiar with the RGU rear speaker wiring. Did you talk to Bill about that? I do know Ultra Classic models do not have a rear speaker connector in the fairing. You may want to wait until Monday to order the LL's and ask them about accessing the rear speaker wires.
You will need a remote turn-on (REM) wire to power up the Amp. Tap into the purple wire going to the cigarette lighter. I made my own by soldering together some 16ga wire with shrink and wire ends. This way I didn't have to cut the stock wire. You can always make one using just wire and connectors. Use a yellow connector on the top of the lighter and put two wires into it. One wire will go to the REM on the power input and the other to the gray plug as shown below.
I assume you have a fuse holder on the power wire at the battery. I am not familiar with the RGU rear speaker wiring. Did you talk to Bill about that? I do know Ultra Classic models do not have a rear speaker connector in the fairing. You may want to wait until Monday to order the LL's and ask them about accessing the rear speaker wires. You will need a remote turn-on (REM) wire to power up the Amp. Tap into the purple wire going to the cigarette lighter. I made my own by soldering together some 16ga wire with shrink and wire ends. This way I didn't have to cut the stock wire. You can always make one using just wire and connectors. Use a yellow connector on the top of the lighter and put two wires into it. One wire will go to the REM on the power input and the other to the gray plug as shown below.
Thanks.
I read somewhere that BT will have a wire breakout for the rear speakers soon. I hope it's real soon!
Thanks.
Thanks.
140wats at 4 ohms, it should kick a$$. I haven't read anything negative about the 1000D.
When I ordered the LL's online, they call me and asked if needed the breakout harness and offered to make me one up and ship it with the LL's. When you call, ask if the RGS need one and I am sure they will make you one up.
1000d should be here in 2 days.
