Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D
Old 12-07-2015, 10:53 AM
Babyboy's Avatar
Babyboy
Babyboy is offline
Default Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D
Just finished my amplifier install on my 14 limited using the stock amp bracket and wanted to share my mods so others do not have to use the OVER PRICED BRACKET FORM J&M
What I did was cut the bracket at the indicated areas and flatten out the areas were the amp was going to mount to get it low enough to clear the fairing.Then bent and reformed the area to get the pieces to realign for welding.If unable to weld I don't see why you couldn't cut and replace the front mounting areas and use angle brackets.Then secure with machine screws
The minimum clearance at the front of the amp is 1/2 of an inch for fairing clearance.
(When mocking up and final install input side of amp is on clutch side and speaker and power on throttle side)
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-1448939250295.jpg
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-2015-12-07-10.05.44.jpg
Bracket after welded and repainted
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-20151201_144304.jpg
When mounting amp to bracket I used #8 machine screws
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-20151201_154345.jpg
When installing amp the wiring harness running along the back of the gauges has to be relocated above the amp so there is a minimum of 1 inch from front of amp bracket to amp
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-20151201_161116.jpg
The side clearance measurments are shown in the pictures.
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-20151201_161058.jpg
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-20151201_161030.jpg
This is the final install picture
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-1449281304648.jpg
Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-1449281334218.jpg
Attached Thumbnails Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-2015-12-07-10.07.58.jpg   Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-1448939285512.jpg   Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-20151201_160952.jpg   Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D-20151201_161156.jpg
Old 12-07-2015, 06:15 PM
haze324's Avatar
haze324
haze324 is offline
Great post man.
Thanks for putting up all the pics and details on how to get this ton. Lots of folks wanting to use this amp in the rushmores without having to get the expensive mount. Props for cracking the code.
Old 12-08-2015, 09:35 AM
Scott14SG's Avatar
Scott14SG
Scott14SG is offline
I have to admit it's a good idea. I couldn't do it as I would know the mount wasn't the same, I'm just weird like that, but it sure saved $$$.
Old 12-08-2015, 09:51 AM
Babyboy's Avatar
Babyboy
Babyboy is offline
That's odd as the part numbers for the RUSHMORE SGS/SG, ULTRA/LIMITED all show the same part number for that bracket
Old 01-24-2018, 05:12 PM
65049's Avatar
65049
65049 is offline
Attachment 452604
Attachment 452602
Attachment 452606
Attachment 452607
Attachment 452610
Attachment 452614
Attachment 452612
Attachment 452613
Attachment 452609
I know this is a old post, but I'm trying to put this amp in my 2008 Electra Glide. It looks like the 2014 has a lot more room in the fairing than 2008
Old 01-24-2018, 05:22 PM
USAproud's Avatar
USAproud
USAproud is offline
Rushmore bikes are a totally different animal than 13 and down bikes. A great easy solution is to get an amp tray from baddazz bikes for 50 and mounting will be real easy.
Old 01-24-2018, 05:49 PM
lefty33's Avatar
lefty33
lefty33 is offline
How does one order this amp tray? Been on their website and can't seem to find it...not the most user friendly site.
Old 01-24-2018, 05:59 PM
USAproud's Avatar
USAproud
USAproud is offline
Best way is to call them. They are in Temple, TX 254-771-0009. Or if you are on Facebook look them up and send them a message. Good guys down there
Old 01-24-2018, 06:02 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
That amp tray WILL NOT work with the stock HU.
Old 01-24-2018, 06:09 PM
USAproud's Avatar
USAproud
USAproud is offline
My apologies. I had the 2 guys mixed up.
Quick Reply: Rushmore AMP BRACKET MODIFICATION FOR SOUNDSTREAM PN4-1000D
