Iron Cross Audio question
I am planning to do an LED conversion to make the backlight on my HK radio match my 2010 Ultra Limited white lights in the dash. In filling out the form, one of the options is for "Conversion W> Updates & Modifications".
What are the "updates and modifications"? If my radio seems to be functioning well, what will these add or change?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
I believe they update your radio firmware and fix some common problems with the radio such as weak mounting brackets. Depending on your year you may or may not need either of those. Call them, they are awesome, and will explain everything. I had the bluetooth audio and rca-outputs added.. didn't need updates or modifications but mine was from a 2013.
Thanks in advance.
Thanks in advance.
Additional liquid prevention on the faceplate PCB
SDRAM rework
Board edge contacts reworked
Faceplate and AUX connectors reinforced
Vibration mod to the audio circuit.
Tuner section and CD section aligned.
UV coating on lens repaired (if needed)
Software update (if needed).
This will include a one year warranty on the entire unit, and a lifetime repair discount if anything ever fails.
