Question on Install SS PN4.1000D
Old 02-06-2016, 01:43 PM
Baja38ss's Avatar
Baja38ss
Baja38ss is offline
Default Question on Install SS PN4.1000D
Trying to make a decision on amp purchase. Was wondering
If it's a must to notch the plastic in order to make the SS PN4.1000D fit securely? This is going in a 08 flhx . Any help would be appreciated.
Thanks
Old 02-06-2016, 09:36 PM
Moto Mike's Avatar
Moto Mike
Moto Mike is offline
Thanks
I had the SS 520D in my 07 SG just using a block of 1/2 inch wood and industrial velcro, just had to raise it up a little to clear the fairing brackets. I think it would be the same with the 1000D, not sure though, I'm sure somebody here has done it! This should bump you back up for help! What HU?
Old 02-06-2016, 09:41 PM
09baggerdude's Avatar
09baggerdude
09baggerdude is offline
The 2 plastic pieces...one on each end of the amp? Just take them off.
Old 02-07-2016, 12:39 PM
Bertk's Avatar
Bertk
Bertk is offline
I think you are referring to the Power Acoustik RZ4-2000D amp. This would be an easier fit with the ends removed. Same power less money.
Old 02-07-2016, 12:58 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,235 Likes on 999 Posts
RZ4-3000 and the 1000D are the same amp. The RZ4-2000 is the same as the pn4.520.
Old 02-07-2016, 02:13 PM
Bertk's Avatar
Bertk
Bertk is offline
Oh yes, wrong amp. The 3000 doesn't look like it will fit in the fairing either.
Old 02-07-2016, 02:48 PM
haze324's Avatar
haze324
haze324 is offline
It does.
Both Power Acoustik amps the 2000 and 3000 versions have removable handles. The two Soundstreams are the same amp and have no handles.
Old 02-07-2016, 04:45 PM
Bertk's Avatar
Bertk
Bertk is offline
Originally Posted by haze324
It does.
Yes, and of course you are correct.
Old 02-07-2016, 09:48 PM
Baja38ss's Avatar
Baja38ss
Baja38ss is offline
Thanks for the help guys. As of wright I'm now I'm sticking with the stock Hu .
Old 02-07-2016, 09:53 PM
azlou66's Avatar
azlou66
azlou66 is offline
For $120 you can buy a Sony DSX 310 HU, huge upgrade over stock.
HDJeff44
02-16-2019 09:33 AM
Stricnine
Audio Systems
02-18-2018 09:13 PM
sic-puppy
Audio Systems
11-21-2015 05:00 PM
pcbreflections
Audio Systems
06-24-2015 10:21 PM
rs03371
Audio Systems
04-16-2014 07:28 AM
Quick Reply: Question on Install SS PN4.1000D
