2015 Ultra System Overhaul
Hey guys,
I am ripping out the stock system (other than HU) and going to do a 8 speaker install. Right now here is what I am working with.
-Polk MMs for Front upper and lower fairing.
-Polk MMs for Rear touring
-Rockford Punch PBR300X4 (front fairing and rear MMs)
These are pretty straight forward and easy, but here is where I am a bit confused..... I am gong to add 6X9 in my saddlebag lids.
Can I add ANOTHER PBR300X4 to run the Lower fairing MMs AND the 6X9s?
or should I run the upper and lower fairing together and get a separate more powerful amp for the 6x9?
Also, if I run with 2 amps, how do I split the preamp signal from the HU? I am already planning on using the BT LL.
Thanks!
Thanks!
I like ur plan for 8 speaks!! More is more!!!!!
I would think about a different amp and 1 way of setting it up would be a good 4 channel like the ARC 600/4 or BT4180 and run front speaks as one group, the rear and lowers as another group in parallel, then get a little micro amp like the NVX MVP4 and run that mounted in the fairing as well to power ur 6x9s bridged and u will have about 175w.
Coming out of your rear line out converter u can use 12-18" RCA "Ys" and get the signal headed to the additional amp. The NVX accepts a 2 RCA input thus reducing "Ys".
Plenty of other options especially if u don't mind putting an amp inside ur saddle bags, but for me that space is sacred so I try and jam everything into the fairing. The NVX and BT4180 will fit side by side on the JM Amp Tray under the hood. The ARC 600/4 might be a tight squeeze but that amp tray will give u about 11 1/4" clutch to brake so check the amp spec measurements if u like the concept of all amps in fairing.
T.
T.
AdmiralAaron (07-23-2016)
Hey guys,
Thanks!
Thanks!
All those speakers will receive 150 watts per speaker and that system will scream.
You will need 2 BT355 line levelers 1 for the front channels and 1 for the rear channels coming off the head unit.
Also don't forget the break out harness to gain access to the rear channels under the fairing unless you plan on cutting into the wiring harness to get your rear signal.
