Tricks to put fairng back on???
I took my fairing off to Dynamat and replace my Mono rca with the new Knu Krux rca. Putting the fairing back on is a major pain in the a**, especially the 2 bottom ones, I basically have to stick the screw on the end of the torx wrench and balance it as I try to get the screw started, besides dropping the screw and not being able to find it ect!! I usaully put the middle windshield screw in and then try to put the lowers ones in, does anybody have a "easy way to do this (especially the guy's that have had their fairings off more times then they can count)!! Is it better to put the two side ones in first, then the bottom ones. Any help will be appreciated!! I will also let you know if I can hear any difference with the upgrade!! I also am going to ask..should I put the polyfill back in or not?? MM
I do exactly as you...middle windshield screw, then bottom 2 and work my way up. Never is easy though. Lol
Moto Mike (07-25-2016)
Thanks again boy's!!
