Biketronics Installation 2017 Road Glide
I'm still waiting on the delivery of the BT355 LL. I wanted to hear it myself before putting everything back together. The amp is stuck down, I have the bracket as high as it can go as the back of the amp is touching the HU. I left room on the Right side for the LL. When I dry fit the headlight, the RCA cables are against it. I may use the Stingers I have to give it more room. As Mike (BT) told me , I'll be sacrificing some shielding. Definitely a close proximity ? The tape went after the first re position. I bought more...
Wow, getting the bike back together and listening to the system. No complaints. Volume isn't half and it's loud. I'm in the garage with doors down though. Not the best acoustics. Definitely not a lot of bottom, but the bass is fine. Did anyone come off the default setting on the Line Leveler ? I haven't put the fairing on yet and can get to it still.
If ur trying to target a certain freq range i.e. Highs, mids or lows then call BT Mike.
T.
Another thought that occurred to me while putting the fairing back on is, If there are another 2 speaker connections on the 2180 Amp, can you get lower fairings with speakers that would have the bottom I hear a lot of you guys looking to achieve ? Is that only in sub woofers ? Can you purchase speakers in a lower fairing that enhance the bottom only ? Will Mid Bass Mid Range cover that or is a Sub Woofer possible ?
I have a 15 RGS with Arc Moto 602's up front, they hammer! I noticed a difference after sealing my pods, (Initially I didn't) so I had something to compare it to,, it's more like a "Ported" bass box, vs Sealed, (my favorite) Granted you don't get a ton of bass from the 6.5's up front, but there was definitely a difference.
Click on the link in my sig to hear my system,, that's just 4 speakers, the TP isn't hooked up, (YET) I need to talk to Gan or Haze and see how and what speakers they recommend,,,, lol
Originally Posted by Bertk
Running speakers in parallel between the fairing and lowers, the speakers would have to the exact same or very close to it. In doing so the lowers would be robbing power from the fairing speaker which are the main source of sound on a bike. Adding lower you would want to use a four channel amp. Considering the cost of lower and another pair of speaker you would do better to use that cash to upgrade the fairing speakers to components with tweeter built into the grills.
First and foremost, it's all about the fairing!!!
T
Got it, the light is starting to come on fella's. This is truly an education... Many Thanks... The Titans aren't bad, but I need to get out on the road to test the system properly. Been Icy around St Louis lately ... Arc Moto 602's ... Hmmmm... May be some new Titans for sale....
