Best way to wire up system????
Frisco, I always suggest to folks who are getting a multi speaker system to purchase from a shop that will ,and can, also provide technical support and provide guidance on the install. It's worth a few extra bucks.
This is should be a pretty straight forward install. 4 sets of speakers wired pos to pos and neg to neg on each amp channel. Set your HPF to roughly 80-90hz for the 6.5 and around 60hz for the 6x9. Turn your radio on to 14 clicks and play some music, then raise each of your gains until you hear distortion from the speakers, then back of the gain a tad. Do this for each channel.
good luck with the install! Let us know how it works out. Do you have spacers for your rear pods? Pretty sure you might need some.
