Lower fairing speakers and what else is needed?
Old 02-06-2017, 06:33 PM
Ecolesh1166's Avatar
Ecolesh1166
Ecolesh1166 is offline
Default Lower fairing speakers and what else is needed?
Hi All,
Okay, here is my deal. Just had a Biketronics 4180.14 amp installed along with Focal KRC 165s in upper fairing and Hertz MPX 690s in saddlebag lids. I now want to install speakers in lower fairing pods. I have a 2016 Street Glide Special and therefore, don't have lower fairings. Can you audio experts please help me out and provide suggestions as to what would be a good speaker and amp combo that would work well with the Focals in the upper fairing, Hertz MPX 690s in my lids and the Biketronics 4180.14. I am thinking about installing a BT 2180 two channel amp to power the lower fairing speakers and put a pair of Hertz MPX 165s in the lower fairing pods; however, I am looking for good tried and true advice as to what speaker and amp combo in the lower fairings will complement my existing set up.
Also, would someone also chime in as to the exact Harley lower fairing pods and additional parts that I will need for the install.
Thanks as always to those who monitor the audio page and provide us with sound real world advice.
Ecolesh
Old 02-06-2017, 11:48 PM
matt76cmich's Avatar
matt76cmich
matt76cmich is offline
Didn't you go to 77 Customs? Did they have any input on lowers?
Old 02-07-2017, 04:03 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
Originally Posted by Ecolesh1166
Hi All,
Ecolesh
After you purchase the lowers you will need speaker housings like this to House your 6.5 speakers:
http://m.ebay.com/itm/322065813602?_mwBanner=1
In the lowers you need LOUD!! Due to the lowers being so far from your ears in the riding position. I've had everything from coaxials in the lowers to subs. Best application during all my testing have been mid range speakers. My friend Haze tested some affordable speakers for that location about a month ago which are highlighted in his new products thread. They are the Tempesta speakers. That said. Those are the speakers I would roll with if it was me.
You wouldn't need another amp. You would run the focals and tempesta's in parallel off the front two channels and run the Hertz off the back two channels.
Old 02-07-2017, 04:20 AM
Ecolesh1166
Initially I was going to go with 77 customs; however, in the end I put together my own set up consisting of Focal KRCs that I purchased frontman Crutchfields and the amp, brackets and Hertz 6x9s from Biketronics. My local shop did the instal, which turned out quite well.
Ecolesh
Old 02-07-2017, 08:37 AM
Bunker's Avatar
Bunker
Bunker is offline
They use wakeboard pods, well that's what I call them but their custom to fit the DD VO's. I never did get to try a set, I was supposed to get a set but that was back when all the drama ensued and they never called me back :/
Old 02-07-2017, 06:26 PM
Ecolesh1166
Gannicus,
Thanks for the recommendation. I will look into the Tempestas.
Spikehorn
Audio Systems
09-15-2018 09:38 PM
DC4MVP
Audio Systems
10-09-2017 10:35 PM
Tweeter2148
Audio Systems
13
12-30-2014 09:39 PM
GoatHD
Audio Systems
04-14-2014 06:41 AM
slammd
Audio Systems
03-25-2014 06:20 AM
Quick Reply: Lower fairing speakers and what else is needed?
