Constant buzzing
Old 02-22-2017, 10:21 PM
lizard86's Avatar
lizard86
lizard86 is offline
Default Constant buzzing
I'm running a Biketronics system, Kenwood head unit, 4180 amp and Biketronics speakers. The fuse on the power cable to the amp blew. After replacing the fuse I have a constant buzzing sound coming through my speakers that seems to go along with the motor.
I've checked the ground and everything seems good there. Any suggestions on what I should check next?
Old 02-22-2017, 10:37 PM
Fatherwayne's Avatar
Fatherwayne
Fatherwayne is offline
I would check and recheck that ground again. Check for loose or corroded connections. After that, check the shielding on the wires. After that check for a nicked our broken RCA. My guess is a bad ground or RCA. Happy hunting!
-FW
Old 02-23-2017, 01:22 PM
Bertk's Avatar
Bertk
Bertk is offline
Couple of questions.
What year and model bike?
Did you determine what caused the fuse to blow?
What model Kenwood head unit?
Is the amp grounded directly to the battery?
How many speakers are there connected to the amp and do they all make the same buzzing sound?
Tokkol
Audio Systems
04-03-2016 07:14 PM
wolf1340
Audio Systems
01-22-2016 04:45 PM
VTwinJaxFL
Audio Systems
11
10-15-2015 07:41 PM
jrod_1286
Audio Systems
01-07-2014 06:49 AM
dapster
Audio Systems
09-18-2013 10:25 AM
Quick Reply: Constant buzzing
