Budget minded build started
#31
#33
Just a quick up date for the guys starting out with an install for the first time. If you are adding larger and deeper speakers to the t/p pods then you will need spacers. I got mine off amazon as they are cheap and there only job is to space the speakers out. If they are ugly then I can paint them. TAILWIND........phoned around for speaker grills. Good luck and no one wanted to help. Asked if they knew where to buy water resistant speaker cloth. Nobody had any idea what I was talking about. I'll find some myself. Have front speakers and crossovers wired and mounted. Ran 8 gauge ground and power to t/p , ran front speaker wires ,and drilled out a couple of small holes in t./p to feed wires into. Also ran an 8 gauge wire from h/u to tour pack for remote. Managed to get the CVO speaker grill from the local dealer and will wire up head unit and interface.
Once again thanks gent.
On a side note . Does anyone know how to fit these into my saddle bags ?
#34
#35
You have to be kidding me ! Thanks I'll look up the thread. You guys do some amazing stuff. I have three in my little GTI and it blows me away. Can just imagine how awesome on a bike it would be.
#37
As TAILWIND calls it. The little brown van arrived today and dropped off my 6" adapters and a new set of RCA cables. Bought the ten foot long RCA . I was surprised as I didn't have much left . Just right. The Metra 6" x 1" speaker adapter will be going to work with me to be modified for my Focal speakers. A not to the guys who haven't used those in the T/P. They are a big speaker so be prepared to do some extra work. Made an amp mount out of MDF and cover it in black fabric and mounted that as well.
#38
So today was the big day. Did a couple of small things. Hooked up the battery turned the key and head unit and amp powered on. Handle bar control worked flawless. Then it went down hill. I could only get one set of speakers to work. Switched the RCA around and the opposite speakers worked. Adjusting the H/U didn't do anything.........not sure what the hell I have done wrong ? All the wires are correct etc. So I started talking things apart. Still no good. While checking the speaker inputs at the amp I accidentally touched the front left wire to rear left and the speaker worked. so on a 4 speaker set up shouldn't each speaker bee on there own channel ? As in left front and so on ? I will have to look into it tomorrow. Had to walk away and take a breather. Not sure if this matters but my battery was low but had my charger hooked up.
#39
The front connections are marked in red in the pics below.
Confirm that the speaker connections are in phase.
Positive to positive and negative to negative for each speaker.
#40
