2014 FLHTK audio suggestions needed
I know, another one of those threads but any help would be appreciated.
I've put up with the OEM equipment and its limitations fairly well, but now I have a tourpak speaker blown and have decided it's time to upgrade.
So I ask the experts here... need suggestions for a decent system (4 speakers, amp, and install equipment needed, im planning on using factory HU if possible) for $700 or less.
-The budget isn't super strict, but to go over it I'd need a good reason/return
-Keeping FM isn't a deal-breaker but I'd like to keep it if possible
-Keeping handlebar controls is a must.
-I listen to everything from country to rap. Not looking for tons of bass but I want to be able to hear more than just the lyrics at highway speeds
I'll be doing the work myself and while I'm competent with tools and mechanicals, any products to simplify install would be awesome.
So let me hear some stuff which will let me hear some stuff! Thanks as always for you input.
To keep it real close to your budget and a fairly easy set up with good all around sound but you will lose the fade option on the head unit.
Digital Design CC6.5 component for fairing $260
Digital Design DX 6.5 for tourpack pods $120
Digital Design D4 amp $280
Biketronics BT355 linelever $80
1/2speaker spacer for tour pack pods $10
Amp wiring kit and rca interconnect and "y" and speaker wire $50
There is a video of this set up in the video section up top
threedeuce5 (04-08-2017)
Honestly I'd never heard of DD products before, but research is promising. I also haven't been in the audio game since the 90's when it was all Clarion, PPI and Kicker, etc etc.
Thanks again man, I'll be looking into it.
For $100 you can add a BT Breakout harness and another BT355 line leveler and keep your fade function but I don't see any reason whatsoever to keep it. Fade on a motorcycle is an unneeded luxury IMO. The setup Rob mentioned is solid. An alternative to the DD DX 6.5s would be what I'm running in my lowers and tourpak, which is the AD Design CX62. I've been super impressed with them, although I've not heard the DDs that Rob speaks of. Good luck. Kudos to you for stopping in here before you buy a bunch of junk and have to try and make it all play together.
Almost got all my equipment purchased and all I have left to buy are the fairing speaks. Here's what I have so far:
Biketronics BTBOC Rushmore PnP kit $214.48 w/forum and military discount
Infinity Kappa 62.11i 6.5" coaxial (rear) $100.95 - amazon
Sound stream PN4. 1000D Picasso Nano $128.99 - amazon
EFX Harley-Davidson Amplifier Wiring Kit $39.99 crutchfield
Krystal Kable 2 Channel 1/2M Twisted Pair RCA Cable $22.18 shipped
Xscorpion SP-DE65 Stackable 6-1/2-Inch Speaker 1/2-Inch Up Depth Extender $6.99 amazon
Dynamat 10425 18" x 32" x 0.067" Thick Self-Adhesive Sound Deadener $26.49 amazon
Think I've decided to go with BBoy's suggestion of the Digital Design CC6.5 but have a question; where/how did you mount the tweeters on your Dad's bike? I can't see them in your video.
Critiques on what i've got so far are appreciated. If i've gone horribly wrong somewhere let me know. It's all still returnable ATM, lol.
Also, that 18 x 32 sheet of dynamat will leave you with very little if any excess to cover a batwing. You won't have the luxury of being wasteful when you cut your panels.
Noticed you're using the BT brackets. Will your suggestion not work with the stock speaker pods? If that's the case then any suggestions for "stock pod friendly" speakers? I don't want to have to shell out for the brackets just yet as my budget will be tight after the DD purchase.
This was based off someone else's recommendation and he's got pictures of how he cut his sheets. We'll see how it goes as I'm gonna copy his Dynamat install.
If so, there is very little extra if any at all.
As for pod friendly speakers, there's a few guys that know what will fit and what wont. I'm not that guy however.
Here are a couple of picture of how I mounted the tweeters in the stock grills.I cut out the center of the plastic support and secured the tweeter with the supplied nut.
