Help-- FLHX Boom Audio Wiring -Ipod/XM
Have Advanced Audio system with Audio Ipod interface Module---Just installed XM
Satelite Radio module with Non Ultra Overlay wiring harness-#70169-06A. Installed exactly per instructions, however, I now have no sound when in Ipod Mode. I have sound output in
all other modes. Anyone have any input on what I need to do ? maybe another connector needed for the Ipod Interface module ?? The Ipod does come up with songs etc when in play mode, just no sound.
Any feedback will be greatly appreciated.
Yes I do , this is the Boom Audio Ipod Interface unit. This was already installed and working properly until I added the XM Audio Radio Kit with the overlay harness as required per the install reqmts. Now i no sound when in IPOD mode. allthe other modes work fine ie FM, XM, CD -- In Ipod mode, the songs come up , scroll etc. just no sound.?????
You'll get more views and replies posting in the Touring forum.
In the meantime, provide a brief description of your XM installation. Presumably, you had to unplug the 35 wire connector from the back of the HK radio; remove some wires from that connector; and, reinsert them in the 35 wire connector on the non-Ultra overlay harness (NUOH).
I'd suspect that the left and right audio wires for the ipod that you had to reinsert into the NUOH's 35 wire connector are not properly inserted. Those are the wires that go in chambers 8 (Tan/Red (?) wire; left ipod channel) and 31 (tan/bk (?) right ipod channel).
It's very easy to feel that the wires are correctly inserted, but they are not--they aren't inserted far enough to make contact when the connector is plugged into the HK radio. An easy way to check is to look at insertion side of the 35 wire connector--the sockets should be up against the red wedgelock's inner surface.
Hope you find a solution.
Carl
Carl
60mike06FLHX
07-07-2008 10:01 AM
