2 ohm speakers
I can't say if they will work or not as I've got limited knowledge as far as electronics go. But someone will chime in here shortly that's more knowlegable than me. I've got aftermarket 2 ohm speakers in mine. I believe that you can use 4 ohm speakers, but it takes more watts to drive a 4 ohm than it does a 2 ohm. My understanding is it takes twice the power of a stereo to drive a 4 ohm than it does a 2 ohm, so they would work, you'd just have to turn your volume up louder to get the same amount of volume. Again, I'm no authority on this, and I could be wrong.
Received 47,786 Likes
Just to be clear ,,,,,
any amplifier that has a MINIMUM impedance rating of 2-ohms, will accept a speaker that is 2-ohms or GREATER, ((4, 8, 16 ,,, as high as 32 ohms if you want)), but as Iron Cross indicated, the higher the impedance, the less power ((watts)) will be able to flow thru the speaker ,,,,
but do NOT use a speaker LESS that 2-ohms like some of the Harley brand speakers which are rated at 1-ohm (((only the lord knows why ?!?)) ,,,,,,
good video here for complete explanation HOW-TO configure/wire 2, 4, 6 or 8 speakers on your Harley Bagger http://www.youtube.com/watch?v=NJj7C...4LpftUbhq26J9L ,,,,,, ,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
There's some good answers and advice here. Anything LARGER than 2 Ohms and you'll be fine. You're pushing power from a head unit to speakers, not pushing power out of a generator to loads. Impedence matching (i.e., making sure you have equal resistance on both sides of the circuit, which is what your ohms represent) is critical with energy draw to maximize it, but in a scenario like this, its no big deal. You'll likely just have to crank your volume up a little more to get the same effect or "loudness".
I'm sure one of the actual stereo gurus could give you a better answer and it will probably turn out that I am as wrong as can be.
