Problem adding rear speakers to 1994 Ultra Classic
Old 03-07-2012, 01:02 PM
trigger1911's Avatar
trigger1911
trigger1911 is offline
Default Problem adding rear speakers to 1994 Ultra Classic
I have a 1994 Ultra classic Electra Glide. I removed the CB and the tour pak that had speakers in it. i want to add speakers into my saddlebags. I never cut any wires, just diconnected them at the plugs. I found the wires for the rear speakers and connected them to a speaker for a test. when i touched the wire to the speaker there was a loud "crackle' thru the speaker and the music went off in the front speakers, no music from the rear one. As soon as i pulled the wire off the rear speaker, the music started playing thru the front ones again. Is this something connected to the CB/intercom system doing this? any ideas? Grounding problems?
Old 03-07-2012, 01:43 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
are you sure you have the speaker wires and not the passenger audio control wire?
on the 94 I'm not sure if the colors are different..
on my 09
right rear speaker is green/brown and green
left speaker is white/brown and white
Old 03-08-2012, 06:07 AM
trigger1911
I have the correct wires.
Old 03-09-2012, 08:10 AM
UltraNutZ's Avatar
UltraNutZ
also if i'm not mistaken on the 94 models, the stock speakers are 8ohms. Is this what you're replacing them with?
andyp
01-17-2009 05:22 PM
Sharknose
01-09-2009 12:07 PM
cubflyer
04-01-2008 09:06 AM
mtbag
12-20-2007 08:28 AM
Slyde
05-05-2006 12:03 AM
Quick Reply: Problem adding rear speakers to 1994 Ultra Classic
