Sound cuts out intermittently
Old 04-01-2012, 05:24 PM
Wallyzworld's Avatar
Wallyzworld
Wallyzworld is offline
Stage III
Default Sound cuts out intermittently
2006 ultra Cvo. Sound cuts out on all sources intermittently. When I flick the speaker switch on the dash on/off if comes back sometimes for a minute to ten minutes. Any suggestions?
Old 04-01-2012, 05:42 PM
Gliden's Avatar
Gliden
Gliden is offline
Bad solder joint on audio preamp circuit common on many hd hk units.
Call iron cross audio Oakland nj.
Old 04-05-2012, 02:53 PM
Wallyzworld
Stage III
Thanks for the tip. Deck is on it's way to NJ. Hope it works!
Old 04-06-2012, 05:02 AM
Iron Cross Audio's Avatar
Iron Cross Audio
Iron Cross Audio is offline
Former Sponsor
Solder joints are fine...never seen a bad solder joint on the audio circuit.
With the 06, it's probably a crack on the main board, especially if you ever had any issues with broken fairing brackets.
Old 09-30-2014, 04:58 AM
DCWC's Avatar
DCWC
DCWC is offline
I have the same problem with my 2008 Ultra. So what was your fix?
Old 09-30-2014, 08:19 AM
Gannicus's Avatar
Gannicus
Gannicus is offline
Post is two years old . . I'd say the fix is a crack on the main board per iron cross . . Those guys are good!
Old 09-30-2014, 10:35 AM
stan60's Avatar
stan60
stan60 is offline
Having the same issue on a 2012. Just sent Iron Cross an email. Hopefully, it's an easy fix.
Raventhik
Audio Systems
11-26-2016 03:48 PM
billnourse
06-10-2014 08:59 AM
knifeeven
09-26-2012 04:52 PM
paul d
Audio Systems
08-11-2011 03:42 PM
mrblister
07-15-2007 11:34 PM
Quick Reply: Sound cuts out intermittently
