Speaker Grills?
Speaker Grills?
Im Installing a pair of 6.5" Titan II's in my lower fairings and even though I like the look of the CVO HD Grills I dont like there Price. Does anyone know where I can find similar looking grills or equivlent at a good price? Also if anyone would care to share some pics of there lower fairing grills that would helpful in my decision as well. Thanx for all the help you guys provide.
I think the way the Focals mount is the base of the speaker grill goes under the actual speaker rim. Then you have this black sticky stuff (can't remember what it's called) that you put around the inside lip of the speaker grill base and then simply push your grill onto/into it. That stuff is pretty durable so I'd think it would stay put.
Well I did get conformation from forum member jb27 here is what he says:
Thanks. I'm not sure if the focal grills would fit your speaker or not. I mounted mine by just pressing them into the space between the speaker and the housing. There was some black sticky stuff that focal used to hold the grill in the rings that were provided with the speakers, i just used that. I had to take the grill out of the rings they came with. They did allright for awhile but eventually vibrated themselves loose as you suspected. I ended up getting some heavy duty 3m two sided tape and used little pieces of it to hold them in a little better.
Good luck with your project.
Jon
So what are you guys all using for speaker grills for your lowers? Looks like I may have to go with the HD grills after I cut 1 arm and leg off.............
Jon
