New Install Kit from Metra - 99-9600
#61
When programming the module, hit the program button on the side of the module whenever you come across a feature that you dont want. The light will flash and then stay on. When it stays on, its ready for the next function on the list. You have to do it in order of functions. When it got time to create a mute button, i just pushed in on the left switch and let go after a few seconds. Checked it and it worked...mutes the radio. So my left switch is vol up, vol down, and mute when pressed in. My right switch is fwd track when pressed to the right, reverse track when pressed to the left and change source when pressed in. Hope this helps. You are using the SWI-RC module from PAC audio, correct?
#64
Find the deutsch connector on the left side of your fairing (right side looking into the fairing). On the SG fairing it is the top one of the two that mount on that side. Remove the pink white wire from the FEMALE side of the connector (learn how to take these apart, very good thing to know). Ground that wire. I just took a small piece of wire, slid it into the female connector I removed from the deutsch and heat shrunk it in place. Then grounded the other end.
To take the deutsch apart you just need a small jewelers screwdriver. Unplug the connector, take the bottom end that comes from the bars (female) and remove the orange plug end (it just pries up and off). Look down inside and you will see a tab. Gently push that tab toward the middle while pushing the pink/white wire out the back. Once loose just pull out the back of the connector.
Guess I opened some eyes here with the mute button - ... now, if we just could do Pause!!!! so I do not miss part of the song (Britney Spears - KIDDING!)
#65
It's funny you say that. My kids have asked me to rewind the radio in the car a few times now. They are so used to having a dvr on the tv. I'm sure it will just be a matter of time until we can pause our radios too.
#68
I guess you have never heard of Tune In Radio?? It's a website (tunein.com) and an app that plays all radio stations all over the country. And the best part?? You can pause playback. That matter of time has arrived my friend....lol.
#70
Mute on PIONEER deck - got it working
Pffff - 4 hours trying to figure it out. manual provides a lot of incorrect information, like led colors and blinking speed.
I am writing up a manual an putting it up on Dropbox, how to auto program and how to assign mute (if your deck does support it!!) the ASWC-1. I will post a new thread and will ask UN to stick it (up to the "boss" )
quick note: on my pioneer Mute is not a full mute (also known as ATT).
so Vol 40, mute, vol goes to 20, 30 goes to 10, 20 goes to 5. pressing the mute again WITHOUT touching the Vol up or down, will bring vol back to what it was. if you press vol up or down after "muting" it resets your volume...
