NIM problems
1 Post
NIM problems
Hey everyone. I have a 2011 CVO Ultra that came stock with the Navigation Interface Module, Garmin 660, and XM radio. Everything worked great up until now. The other day my Garmin stopped sending commands through my speakers, and the radio doesn't cut out. The speaker switch is in the right position. I can run a cable from my GPS to the Aux input on the radio and can hear the commands that way, But then I can't use my XM radio because I have to have the radio on aux.
I figured the NIM went bad, so I borrowed one from a friend who had a new one laying around. I still had the same problem after replacing the NIM. I tried running a cable from the input on the Garmin cradle harness to the aux input on the radio, but couldn't get any sound out of the speakers. I'm wondering if the cradle harness is bad. Also, since the bike came stock with the NIM there is no overlay harness. I spent the better part of 4 hours reading posts, but couldn't find anyone with the same problem. I live in Mexico and the nearest Harley Dealer is 400 miles away in Tucson, AZ. I have the extended service plan, but I'd rather try to fix it myself if it isn't to expensive than drive all day in 100 degree heat, sit around at the dealer all day while they try to fix it (assuming they have the parts), and then drive another 400 miles back home.
I do all my own wrenching on my bikes. I hope someone can point me in the right direction. Thanks.
ericedelman
02-25-2011 06:11 PM
