2014 Audio upgrade parts ordered
Hello everyone,
21014 Limited -
Finally I have ordered the parts to upgrade my audio system (front speakers amped rear just speakers no amp. Can you please let me know if I need anything else?
Thank you so much
1 - Rockford Fosgate Punch PBR300X2 = $169
2 - Infinity Kappa 62.11i 6.5 (2 Pairs ) = $216
3 - DSP Line-Level Shifter (Magic Box) for 2014 Harley Radios - (Front Speakers) $69 + shipping = $82
4 - 2014 Harley amplifier wiring kit for PBR300x2
(151328364051) = $29
5 - 2014 + Harley batwing amp mount for Rockford Fosgate pbr300x2 (161256797212 ) = $29
Total = $525
21014 Limited -
Thank you so much
Total = $525
I didn't feel the screws supplied with the speakers were a big enough diameter so I used some "fatter" ones, also shorter as the ones you get are kind of long and will stick out the fronts of the pods. I am assuming you are going to put the speakers "IN" the pods (split the pods in half to install)
Do you have a solder gun, solder, heat shrink, wire harness material, wire connectors (a "t" tap to get power from somewhere for remote amp turn on)?? I pulled power from the cigarette lighter (purple wire) but I spliced and soldered.
Let us know how it goes!
Hello everyone,
21014 Limited -
Thank you so much
Total = $525
21014 Limited -
Thank you so much
Total = $525
Oh and BTW I spoke with cycle sound and they will come up with a magic box for the rear in less than a month. I will then get the second PBR 300x2 for the rear. Like I said I don't want to deal with the dealer flashing BS.
You know Eshaw this is so confusing, I talked to the people at Biktronics and they said that's the way I should set it up, I was going to get the Fosgate Power amp t400ad, but I thought it may be to much on the charging system. The magic box only works for the front and if use for the rear would be loosing the controls, and I don't what to have anything to do with the dealer flashing. I don't need musch more power than I currently have with stock so hopefully it will still be OK.
http://www.cyclesounds.com/line-leve...rley-2014.html
I would put 2 PBR300x2 amps (1 front and 1 rear) before I put that AD amp in there. I cannot get the guys at Bagger Nation to respond to any emails about the installation and it's use with these limited charging systems.
they already have the magic box available for the rears. It's on their site and I know folks have ordered it already.
