Installed Biketronics 2014 BT7P14 Speaker and BT2180 Amp Upgrade
Old 09-19-2014, 10:37 AM
FLYINGBROKE's Avatar
FLYINGBROKE
FLYINGBROKE is offline
dealing with it now,I have 1amp two speaker in now going back Saturday to try 8speaker 2amp flash per biketronics instructions .also make sure they do not put latest flash in you want 17.4,apperntly new flash has opened up another can of worms.
  #32
Old 09-19-2014, 01:42 PM
nofd843's Avatar
nofd843
nofd843 is offline
Ok, so this is what I learned... You want the 8 speaker 2 amp flash. They then need to go in to a second menu on their laptop where the select AUDIO. They then go in to the amplifier section and check no next to to both Amp 1 and Amp 2. This should help prevent throwing codes. Mine still throws the "radio cannot communicate with amp" fault. The only place you can see this fault is on their laptop.
  #33
Old 09-19-2014, 02:55 PM
FLYINGBROKE
nofd843, are you saying you still have code even after proper flash. and if you still have code did this flash make you happy do you feel it is correct sound.
  #34
Old 05-23-2015, 09:27 PM
letsgomurphys's Avatar
letsgomurphys
letsgomurphys is offline
I didn't get the I connector with my kit. Is there a way to hook up the amp without that? I tried and the gain controller started overheating.
  #35
Old 05-24-2015, 08:13 AM
Smokey Stover's Avatar
Smokey Stover
Smokey Stover is offline
Here's Bill from Biketronics reply in another thread concerning polyfill copy/pasted.
https://www.hdforums.com/forum/attac...rade-image.jpg
I don't mind if someone uses polyfill as long as they don't have it packed so tight or tied to the speakers in a way that effects the airflow needed to keep them cool. I worry when I see pictures of polyfill zip tied to speakers or taped around them. And I didn't see a big enough difference with it installed to balance out the worry of a bad installation so we don't usually recommend it. We have seen parts that had been wrapped in polyfill that had gotten wet a couple of times, not good.
The stock head unit does put out a ton of distortion, that might be some of the vibration in your fairing.
Bill
__________________
http://www.biketronics.com
1-800-735-2419
  #36
Old 05-24-2015, 08:20 AM
Smokey Stover
And a photo of my install, Sony MEX-GS810BH, 2180 amp, 7.1's, Retro kit 1005. I have since removed the HD hidden in fairing antenna for a rear rubber stubby, Much better reception.
Fxstsb6
04-29-2014 07:09 PM
vlegath
10-11-2013 07:59 AM
harley.farmer
Audio Systems
02-15-2013 06:50 AM
cabowabodude
06-30-2012 02:50 PM
blackswampbiker
04-06-2011 01:13 PM
Quick Reply: Installed Biketronics 2014 BT7P14 Speaker and BT2180 Amp Upgrade
