Installed a Kenwood this evening
Installed a kenwood 598, decided I didn't need the 798 and it's rear USB so saved the $50 and did the 598. Really drives the bt 7.1 and bt 2180 a lot louder and cleaner, but man is the eq going to take sometime to get in the sweet spot. Anyone who has a similiar set up and would like to share how they set there eq I would greatly appreciate any guidance you would be willing to share!
Glad you pulled the trigger on a Kenwood they are a good HU. The eq has alot of settings. But when you hit that sweet spot you will know trust me. I have the loud setting on but not sure if it's the same as sony. I dont know if your hu has the setting for each source that controls the volume but when I got mine they had it set all the way down on all sources. I turned them all up and it made a big difference. I am going to try the powerful eq and see what I think . Kave Dweller I am in the same boat as you. If you find that sweet spot please share it with me I think I got mine but yours could be even sweeter.
Once you select "powerful", you can change what you want individually.
Once you adjust it, it's not considered a pre programed eq setting anymore. It's a "user" eq setting, and not labeled "powerful" in your scrolling menu anymore, IIRC.
Ended up with about 175 miles today, just using the user defined eq, got it sounding really good, highs are perfect, playing the fine line with adding lows without distortion at 25-26 on the volume is the sweet spot I have quite nailed down yet but for sure closer, thanks for the input, I really love this system!
Cool glad it's working out. Messed around with mine Sunday and not sure what I did but I screwed something up it sounds like crap. I will not have time to look at in until Friday. This thing they call work really gets in the way of other things I want to do . What can you do I guess.
