Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
Aerocharger & fuel in motor oil
Old 04-25-2015, 11:41 PM
Springer*'s Avatar
Springer*
Springer* is offline
Stage II
Default Aerocharger & fuel in motor oil
I have 1993 FXSTS with a intercooled Aerocharger turbo and it is getting fuel into the motor oil. I put the kit on in 1994 and it has been great until recently. The bike runs fine and you would not suspect a problem without looking at the dip stick. I have checked most everything that I can think of that would cause the problem. The fuel pressure regulator diaphragm is good and I cut the fuel pressure to 4psi. The cylinder compression is 155 both front and rear cylinders. It is running a Mikuni carburetor and I have had it apart but found nothing visibly wrong. The spark plug reading is good and like I said the bike runs great other than the fuel oil mix. I do not have a boost gauge on the bike so I do not know what the boost is but nothing has been changed in 21 years. Has anyone had a similar issue or have any thoughts about what could cause the problem? Yesterday I put fresh oil in the bike and left it on the low side. In 20 miles it was over 1/2 of a qt higher on the dipstick and you could clearly smell gas in the oil tank.
Old 04-26-2015, 06:45 AM
GraemeR's Avatar
GraemeR
GraemeR is offline
I would have thought buggered rings, but if the compression is good? What about a leak down test?
Old 05-17-2015, 12:00 AM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
My initial thought is rings and a wet compression & leak down tests might be telling - especially after 20 years of boost on an air cooled motor. Perhaps they are not sealing well under boost pressure.
My second thought would be a heavy float (if it's not the sealed plastic one), or something allowing the carb to dump fuel - even a bad needle/seat seal.
Has the main needle worn a notch into the guide after all this time and boost?
It sounds like you checked for fuel in your regulator line. That's a lot of fuel in 20 miles so it;'s surprising it's not jumping out.
Old 05-17-2015, 09:16 AM
FastBagger07's Avatar
FastBagger07
FastBagger07 is offline
Sounds like your running it too rich.I'd get it on a dyno and see where your at with your AFR.You'll end up washing the rings out if you don't.
Old 05-17-2015, 06:25 PM
GraemeR's Avatar
GraemeR
GraemeR is offline
Another one post wonder by the looks of things!
Old 05-17-2015, 06:28 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,273 Likes on 11,143 Posts
So!!! It seems legitimate. Maybe they guy Googled for help, and found this forum.
Old 05-18-2015, 06:21 AM
GraemeR's Avatar
GraemeR
GraemeR is offline
So!!!! Common curtsey to let folks know its resolved and what the fix was. I reiterate...A 1 post wonder.
Old 05-18-2015, 07:40 PM
FastBagger07
What the heck is a Trike Guy doing over here on this thread?LOL
Old 07-15-2015, 12:54 PM
Springer*'s Avatar
Springer*
Stage II
I am not a one post wonder. I have been out of town for two months and I have also lost interest for a while due to the extreme heat in Arizona, 116f recently. I don't ride the bike much when the temperature is over 100f.
Next week I hope to have the time to do a leak-down test. I am also going to install a boost gauge on the bike at that time. I will post my findings after I do the testing. The bike is a 1993 but it only has 7,00 miles on it. It has been well maintained and never abused. Thanks for the suggestions on the cause.
Rockhavok (08-29-2021)
Old 07-16-2015, 05:45 AM
GraemeR's Avatar
GraemeR
GraemeR is offline
Welcome back! keen to see how things pan out on this.
journeymanjohn
EVO
25
05-04-2019 07:02 AM
0734
Engine Mechanical Topics
29
09-11-2014 11:20 PM
Kisse87
03-31-2010 07:04 AM
WARG
Exhaust System Topics
08-01-2008 08:54 PM
WARG
02-24-2008 08:15 PM
Quick Reply: Aerocharger & fuel in motor oil
