Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
Cam for Procharger
Old 11-29-2016, 10:51 AM
Evosupercharged's Avatar
Evosupercharged
Evosupercharged is offline
Default Cam for Procharger
Hi everyone ,
I have a 585 cam In my 111 s&s running 13 pounds of boost
Any cam recommendations ??
I think this one don't allow the engine to rev much
Thanks
Old 12-02-2016, 11:26 PM
Boost's Avatar
Boost
Boost is offline
The S&S 585 cam is a mid range to High RPM cam. It has 245/260 deg duration and 40 deg overlap. If your running out of gas at high rpm, I don't think the cam is the issue.
There are a lot of areas to play with to determine where your hidden power is.
You have an Evo so I assume you are still running a CV carb. What is your AFR at higher RPM. Are you using a third fuel circuit (thunderjet)?
Have you had head work done?
What exhaust are you using. You have a 111ci engine. Exhaust designed for an 80ci Evo might not be the best choice for a supercharged S&S 111.
Timing?
Old 12-11-2016, 11:20 AM
InthewindMN's Avatar
InthewindMN
InthewindMN is offline
Originally Posted by Evosupercharged
Hi everyone ,
Thanks
You could try calling Dragos Bike Works. I believe he does a lot of work with pro chargers.
jmd897
Engine Mechanical Topics
14
06-14-2019 11:27 AM
evobigape
EVO
11
03-07-2018 05:46 AM
FXD95
Exhaust System Topics
05-04-2010 06:34 AM
90evo
12-25-2009 06:16 PM
beeoh
10-18-2007 07:16 AM
Quick Reply: Cam for Procharger
