Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
Tuner for boost
Old 08-09-2011, 01:38 PM
belsebub36's Avatar
belsebub36
belsebub36 is offline
Default Tuner for boost
Hi!
Which is the best tuner for blower/turbo?
I have great experience with PCV but like to test the full replacement ECM like T-Max or Twintec TCFI III.
Old 08-10-2011, 03:19 PM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
DRAGO'S BIKE WORKS is offline
Former Sponsor
In your area if you dont have a good tuner I would go with the Tmax 2 bar map sensor and Auto tune.
Originally Posted by belsebub36
Hi!
Old 08-11-2011, 12:49 AM
belsebub36's Avatar
belsebub36
Thanks Drago!
With 2 bar map sensor can I boost maximum 2 bar or is it only 1 bar as ground level is about 1 bar pressure?
Do you know if its possible to use a quickshifter with the t-max?
Old 08-11-2011, 07:11 PM
DRAGO'S BIKE WORKS
Former Sponsor
Manifold Absolute Pressure Sensor The pressure inside the intake manifold is an extremely important input to the ECU. This Sensor will respond to changes in manifold pressures and relay the information to the ECU in the form of a voltage signal ranging from about 0.2 volt to 5-7 volts. MAP Sensor 2-Bar for blown or turbo applications up to 16 lbs of boost.
And the quick shifter I would say no.
Thanks Drago!
Old 08-12-2011, 01:39 PM
belsebub36's Avatar
belsebub36
I saw that you is an reseller of the T-Max.
What is the price and do you ship to Europe?
AKL1
01-19-2020 03:03 PM
Lwood10
07-10-2019 02:54 PM
12, Bob Street
03-11-2015 12:46 PM
Takedown
06-24-2011 08:17 PM
jluvs2ride
11
03-11-2009 12:20 PM
Quick Reply: Tuner for boost
