Supercharged Sportster
#81
#82
Fast Bagger ...231hp and 190? lbs torque wow very impressive. We found compitant builder for 2008 Road glide 127ci under square long stroke engine. Produces 215hp 185lbs torque. Went with 21 inch front rim 18 back rim , Metzler tires Bitubo race shocks and also upgraded front with progressive high performance cartridges and Ohhlins steering damper. Point was to upgrade chassis/'suspension to handle the mass ive increase in power . NOW with new technology on the market we are REALLY going to improve the build. Grip One Chronos TC Traction control. Now the rider can use the 200+ horsepower .With traction control you can lay on the throttle exiting in a controlled slide not fearing the infamous highside or lowside .Also if you hit gravel, rain ect The new Traction control units keep all in control instead of sliding down the road. IMHO the BEST upgrade you can add for any Procharged/Supercharged Machine. With 238 hp take a look into the system . Take care Jake
#84
FastHarley... Not only do you have a beautiful, fast build . BUT you have a SMART build .
Impressed that you where smart enough to upgrade your Suspension. No use having tons of power that the rider is leery he will highside having fun riding on cool twisty roads.
And the Procharged/turbocharged Baggers benefit from updated Suspension/brakes even more. Good Job Jake
#85
Evo there are units that cut power via the coil , but it doesn't work all that well. The New tech traction control units are great . They don't ...ride the bike for you ... They allow you to use more of your Supercharging/Turbocharging units. Example: If the rider gives TOO much throttle coming out of corner , instead of your rear stepping out too far /tank slapper ect . The traction control will give you the correct amount of power to drive out of corner fast and strait . IT HAS LIMITS . I wouldn't count on a traction control unit to stop handling problem of leaking for seals ect but they really work well.
2012, 99, chargers, harley, harleys, hd, kit, nitrous, oxcide, sportster, sportsters, super, supercharged, supercharger, turbo
