Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
Supercharger with turbo Wastegate Install
  #31
Old 09-02-2014, 05:59 AM
sgod1100's Avatar
sgod1100
sgod1100 is offline
Originally Posted by ProCharger
The 2006 and earlier bikes have a different bracket/tensioner assembly than the 2007 and later stuff does. On those bikes room becomes an issue.
The newer ones it isn't a problem. We have them in both 4 rib and 6 rib configurations.
oh ok, thanks for the info, that's good to know.
  #32
Old 10-14-2014, 03:04 AM
TD302's Avatar
TD302
TD302 is offline
A mate of mine is getting a Gilmour belt setup machined up for his (06 Softail 106 14psi from memory 197rwhp) will be keen to see it. Will try and te a photo.
Reindeer
08-18-2023 09:47 AM
Iron lHorse
01-22-2015 07:29 PM
rearnold
44
09-24-2011 05:46 AM
jeff.georgalas
01-29-2011 11:21 AM
RangeRat
11-26-2008 07:43 AM
Quick Reply: Supercharger with turbo Wastegate Install
