Tmax Tuner or Smartlink for boost..HELP!!
Hi!
I'm building a procharger application with T-max.
My bike is a dyna 2010 so it is a throttle by cable.
My question is how do i handle the boost in the Smartlink software as I dont have the the Fuel correction vs Boost and Timing vs Boost?
They exist in Zippers Tmax Tuner throttle for wire software
See attachments
See attachments
These 2 maps exist in the Tmax tuner software..throttle by wire only(at least what I know of). I have the throttle by cable software smartlink.
I will use a zipper 2bar map sensor so some how I want to adjust the fuel and timing depending on what boost I have..like you can if you have those 2 maps.
So I wonder how everyone compensates in the fuel and timing maps for boost if thet use snartlink software?
