Blowers/Turbos/Nitrous Oxide For you Gear Heads. Here is the place to discuss your souped-up, sophisticated, out of control and money pit monsters.
Head Work for a Turbo Engine
Old 11-23-2015, 04:32 PM
FastBagger07's Avatar
FastBagger07
FastBagger07 is offline
Originally Posted by GraemeR
Okay, So I have a spare set of stock Evo heads in the shed and figure that it might be a good idea to have them worked a little bit and then bolt them onto the turbo engine.
Now I know that all the work you do porting heads for a normally aspirated engine is designed to allow air/fuel to be drawn into the engine in high volume and speed. BUT what about turbo setups??? I mean; I have 5lbs of boost pushing the air/fuel mix into the engine, so does the same theory apply?
In my mind the design would have to be different; but then again my mind is a strange place at times.
Cheers
Give Frank a call over at DragosBikeWorks{815-765-1790} he's the absolute best in the biz.
jackinthebox
03-24-2009 10:23 AM
Papamte
Screamin Eagle CVO Models
09-15-2008 04:22 PM
HDDyna2006
Exhaust System Topics
05-26-2008 11:40 PM
dlstanf2
02-11-2007 10:50 PM
HDF Tech
Engine Mechanical Topics
08-03-2005 12:43 AM
Quick Reply: Head Work for a Turbo Engine
