Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Help with petcock truobles please
Old 01-22-2015, 01:06 PM
usdart's Avatar
usdart
usdart is offline
4th Gear
Default Help with petcock truobles please
So I had a leak and replaced the fuel line to the carb from the petcock. I had to syphon the gas out of the tank because it would not come out of the pet **** in 'ON' or "reserve'. I took the tank off and could not blow through it either.
Is this normal? I am thinking the petcock should flow gas on it's own, Do I have a blockage, and can you disassemble the petcocks and clean 'em out?
Bike will not start now, so I guess that is my answer?
2003 /1200S
Old 01-22-2015, 02:40 PM
Am4wag's Avatar
Am4wag
Am4wag is offline
There is a nipple on the petcock that should have a hose going to the carb./intake.Vacuum needs to be applied in order for gas to flow.Think of it like this-gas will not flow unless the engine is running (creating vacuum).So you'll need a hand operated vacuum pump to create vacuum if you want to drain the gas.
Old 01-22-2015, 04:16 PM
usdart's Avatar
usdart
usdart is offline
4th Gear
Perfect..that is what I thought.
Thank you, you saved me a lot of anguish.
Old 06-02-2015, 01:08 PM
JSteel's Avatar
JSteel
JSteel is offline
1st Gear
Default Installing a new petcock
Might be slightly off topic, but when installing a new petcock would you recommend using a teflon tape as a thread sealer?
Old 09-20-2016, 05:48 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,922 Likes on 3,022 Posts
Not needed, it's not under pressure. There's a rubber gasket.
MJHJEA
EVO
47
07-27-2022 08:38 PM
fastalkintn
04-09-2013 01:27 PM
otter8
03-24-2011 03:40 PM
hammr_hed
01-22-2008 07:54 AM
imboden
Classic
05-14-2006 04:58 PM
Quick Reply: Help with petcock truobles please
