Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
91 evo intake manifold seal leaking problem!
Old 05-29-2015, 08:18 PM
dirtygurty's Avatar
dirtygurty
dirtygurty is offline
Default 91 evo intake manifold seal leaking problem!
my 91 evo has a s&s super E and a s&s intake and the seals started leaking last week and I replaced the seals today and still have a leak, I found the leak by sprying carb cleaner around the intake flange with the motor running and she dies when I spry ether side?...is there something I am over looking or not doing right?
Old 05-31-2015, 09:28 AM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,726 Likes on 924 Posts
Make sure the carb is not sucking in whatever your spraying...get a big piece or two of cardboard and slip in (cut to fit) between carb and engine to make sure the spray is not getting sucked in.
Also check alignment of your carb mounting brackets (whatever type your using) to make sure it is not torqueing your manifold or carb when you cinch things down. Good luck. YD
Old 06-02-2015, 02:20 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,785 Likes on 3,301 Posts
Between the carb and intake is an isolator with an oring on one side take the carb off and check it. Also check the vacuum line to your voes switch and vacuum hose. either or can cause it..
Old 06-02-2015, 02:44 PM
dirtygurty's Avatar
dirtygurty
There is no switch the hook up on the manifold is plunged off
bigjayree
EVO
09-14-2015 04:05 PM
JD73
Exhaust System Topics
10-30-2013 11:06 AM
TXbobber
10-21-2012 09:03 AM
pointdogg48
Shovelhead
10-08-2012 07:16 PM
gnafin
EVO
15
11-24-2009 10:57 PM
Quick Reply: 91 evo intake manifold seal leaking problem!
