Rejet due too altitude
what is your current elevation? does your bike run good at your current elevation? Sturgis elevation is under 3500 feet so I would think that if your bike is running good at sea level, or close to it it should run decent at 3500 feet. You could always bring along a main jet sized smaller just in case. Now if you wanted to run it in Denver air then id say you need to jet down but I think you'll be ok.
