Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Winter Storage
Old 11-12-2015, 03:40 AM
tpb857's Avatar
tpb857
tpb857 is offline
Default Winter Storage
Going to change the oil and clean up the bikes for winter storage this weekend. I bought my shovelhead back in July and it is the first carbed bike (S&S) I've had in quite a while. I always put some Sta-Bil in the fuel tank for the winter. As far as the carb goes, is it best to let it run dry or to keep fuel in it for storage? Thanks.
Old 11-12-2015, 09:19 AM
y22c's Avatar
y22c
y22c is offline
What ever you do for the carb...nothing wrong it letting it run dry I would think seeing how stored my FXDX many year that way.
Just make sure you run the engine a bit, say 10 minutes after you change the oil to circulate the new oil through out the engine.
Old 11-12-2015, 06:06 PM
skinman13's Avatar
skinman13
skinman13 is offline
what is this "winter storage," of which you inquire? We ride all year long here...unless the roads are underwater. Winterizing for me is putting on the windshield, and breaking out the long-johns, balaclava, leather riding jacket, and chaps, and start layering up...
Honestly, I have never lived in a place where I could not ride for months on end so I am curious, you really can't just crank your ride up once a week and let it run for 20 minutes or so? I mean, how difficult is that, and it seems to me that a once-a-week engine run would be better than just pushing it to the back of the garage, throwing some stabilizer in the tank, and tossing a cover on it for four months.
Old 11-12-2015, 06:10 PM
Sticks24's Avatar
Sticks24
Sticks24 is offline
Fill the tank full, put the right amount of stabilizer in. Shake the bike back and forth. Start the bike and let it run for a bit, so that the fuel in the carbs is stabilized. I then as an added measure spray stabilizer into each cylinder with the plug removed. This year I will be storing my bikes in my heated barn for the first time.
Old 11-13-2015, 09:16 AM
tpb857's Avatar
tpb857
tpb857 is offline
I wish I could ride all year long. The cold doesn't bother me. It's how the roads get. Potholes all over the place, cinders and a lot of salt. I thought about running both of my bikes occasionally in the winter. My concern is that by the time that they got hot enough to burn out the water, especially my shovel, I would have fumes all over the place. I have an integral garage. Anyway, for me, it is actually easier to change the oil, wash and wax them and cover them up. Occasionally, I'll light up a cigar, grab a beer, pull the covers off and just look at them and wish it was spring.
Thanks for the responses.
Old 11-13-2015, 06:26 PM
skinman13's Avatar
skinman13
There are snow/rain/nasty winter days in northeast Alabama where I grew up but not for months, and it can get nasty cold here and ice over the roads overnight, but no snow for many years now. We get rain that floods all the major roads...Ford F-150 days.
Old 11-22-2015, 09:01 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,809 Likes on 3,314 Posts
That last thing you want to do is start your bike in the cold winter months and let it run for 20 minutes. It will lead to more moisture in the oil as the motor cools it will condense on the inside. shut the pet **** off and run it out of gas or just simply drain the float bowl and yea stabil in the tank. You'll be good....
Old 11-24-2015, 11:12 AM
skinman13's Avatar
skinman13
Are you suggesting that riding my bike for 20 minutes to and from work once or twice a week is bad for it because water will condense in the oil?
This doesn't make any sense. Anytime you run the engine, you eventually shut down and the engine cools. Spring, summer, fall...and now you allege that damaging condensation in the air that will foul the oil suddenly appears in the colder months?
I can appreciate that if the plan is to park it in the back of the garage, toss a tarp over it, and leave it unattended from November till March, then, yeah, you need to do something about the gas system. Filling it up and running some kind of stabilizer through it is one approach. Corrosion should be considered before completely draining the system, including the bowl. Leaving stabilized gas in it would seem to be a better choice.
With long-term parking small airplanes, they get a full bag of fuel, maybe add some stabilizer depending on how long it is going to sit up, do a good run-up to get the stabilizer mixed in real good, and then park it...Then it is pulled out every month or so for another good run-up. When it is time to fly it again, it is given a good inspection, fluids changed, everything is tweaked and primed and away it goes. I don't see why the same would not work for a Harley Davidson as well if the owner was motivated enough to keep at it all winter long.
Old 11-24-2015, 07:29 PM
98hotrodfatboy
Absolutely. You don't live in the north, so don't go there buddy... If I really have to explain it would suck.... just think 0 to -20 degrees???????
Old 11-25-2015, 12:43 PM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
Hook up the tender and cover it up. I've never turned my gas off and it sits 4-5 months. Come spring, jump on it and go.
Quick Reply: Winter Storage
