HELP 2004 heritage dies on throttle up
i have had the carb out and cleaned it good, i think. after replacing, it starts, idles, and dies on throttle up. i did pop out the plug for the air mixture jet. unscrewed the jet for cleaning and didn't screw it all the way in to count the turns. not sure if that is it as i have been all over that adjustment starting out at 1 3/4 turns. any/all suggestions greatly appreciated not a carburetor expert but want to be
Pull the air cleaner and see if it is squirting gas down the carb throat when you twist the throttle. That is the first thing that comes to mind right off-hand. Could be something with the slide also.
I would pull it all back off and go back through it and make sure that everything is where it should be, put it all back together, set the mixture 2 turns out, and fire that bitch up.
