Mikuni choke cable is missing the spring clip.
Well since there were no responses I guess once again I'm the only one with this problem. I did recall that I had an old 40mm Mikuni up in the attic so I climbed up there and sure enough it used the same choke cable as the HS42 and the little spring clip was still there. I popped it off and it snapped right into the cable and works great! It's just a piece of spring steel sort of shaped like an unfinished D. Between a P and a D. The straight part is what slides into the groove of the shaft. So if you have some thin music wire you could easily make one.
